Finally got my 2 new QB 2’s and 1 Mu-so 2 delivered today to replace my Sonos units and add to my Nova & Atom systems.
First set up the Mu-So 2 without any issues at all. It is hardwired to my router in my living room. I was able to find the speaker in Roon under “Roon Ready” devices and enable it, and play it from Roon. In the Naim app, I can select the Multi Room and add it to the Nova or Atom. Everything works great.
Set up the first QB 2 in the kitchen… this is NOT hardwired, so I set it up wireless. I did notice as the app was going through the setup it mentioned “Setting up Airplay device, etc” which I thought was strange.
Anyway going into Roon after the Kitchen device showed up in the Naim app - the QB 2 is ONLY listed as an “Airplay Device” in Roon. It is not listed as a Roon Enabled device at all. It DOES play directly from the Naim app.
Multiroom: When I go into the Naim app, with the MuSo 2 as the “master” device, I can select the Kitchen QB 2 to group, but there is NO sound coming out of the QB 2 when it is grouped. Sliding the volume on the QB 2 in the app does correspond with the volume indicator moving up and down on the actual QB 2 indicator but no sound comes out so it seems to be a streaming issue?
When I select the Kitchen QB as the “master” device the MuSo 2 no longer shows up as an option to group in multi room, only the Nova and Atom.
Would love some ideas if possible? Seems like maybe a glitch during the initial firmware update or something?
My main purpose behind using the QB/MuSo’s instead of Sonos was to use them all in Roon as Roon-Ready devices/Zones with the Nova & Atom. So the multi room grouping in the Naim app isn’t a big deal but if the QB 2 won’t show up as Roon Ready in Roon then it’s pretty useless.
Thanks!
