So my brand new Pro-ject VC-S2 ALU has just arrived and I already have a concern even before cleaning my first record.
I assembled it as instructed and just checked that everything is working as expected.
What I noticed is that, when rotating, the spindle is not perfectly straight but translates a bit in position leading to the platter showing about a 1 millimeter difference in edge height as it rotates.
I also checked with a spirit level. At some points it is perfectly dead on straight and then rotate it a quarter and 1 mm off.
Is this something to be concerned about? Or is this kind of error acceptable ?
Try cleaning a record. When the vacuum is on, it sucks really hard and the record sticks to the cleaning arm. I very much doubt it will make a jot of difference.
That is very true. It was just not foremost in my mind.
And honestly the cost of the RCM can be prohibitive. Well at least at my side of the paddling pool. Because at the end of the day it is really about experiencing it for yourself.
The need for it has to be convincing enough to spend the cash there and not elsewhere in the system.
Thankfully, for me, the good folk especially here made a very convincing case for it!
I wouldn’t be without mine, OK mine I made myself but I would have been just as happy with the results no matter what I paid, I honestly think it is the most essential part of my vinyl playback
