New Rega skeletal entry level turntable
Replay
Looks like a good turntable for anyone buying an Io and Kytes, or similar.
I have a Planar 8 so I already like the look of the Replay, though others won’t and may prefer the more traditional Planar 1.
Reminds me of a modern take on the Systemdek II
Does it have a built-in phono stage?
Its even cheaper than a P1, a rather cool looking match to IO/Kyte, bet it sounds good too.
Nice! :ok_hand:This turntable might just be the one to persuade me to get into vinyl! :slightly_smiling_face:
(it looks much better than the rather plain P1/P2 imho. It reminds me a bit of the AVID Ingenium.
Very curious how it will sound. I’m sure it would be a great match with my Rega IO. (I assume less so with my Nait 50, as it deserves something much better)
I think the IO deserves better too. Mine did awesome with my P6.
I like it a lot though, definitely a ladder starter…my reentry into vinyl started with the previous gen P1 (which if we are honest, was a bit of a POS).
With lower mass, possibly sounds better than Planar 1, which would be win-win.
Exactly, and more Win/Win once you get a Carbon Pro stylus upgrade replacement, me guess.
This is a great move by Rega, imagine a cool entry level product to get you into this hobby.
Then after a while you get the urge to upgrade and hey presto what a range of upgrades are available to you.
Certainly something many manufacturers could do well to replicate if you want long lasting relationships with you customer.
‘like’
Yes, Rega do have a good line of products to take you through from entry level and on from there. I presume having a strong OEM business to keep the bottom line healthy and the Employee Ownership Trust to uphold and protect the core company values helps here too.
Wouldn’t touch any of their products due to quality control
Martin
Good for you. I’m not sure how it helps advance the discussion.
Still waiting to see some new products from Naim. You guys watching Eversolo? That could have been Naim quite easily.
@JasVerlen How does your comment advance the discussion of thE NEW Rega TT?
Well it would be nice to see a discussion on a new Naim product. It has been a long time
@JasVerlen Then start a new thread.
Ok Sergeant! But kind of hard to do since there is no new product.
@Martinzero When I had a Rega system l had QC issues with the Saturn. Not with their turntables. Again this does nothing to advance the discussion of the new Rega TT. My issues with Rega had to do with UI displays. Orange letters on an orange background. Very hard to read.
