Just been ripping the new Garbage CD, which was out last Friday. When I ripped it on my Star no metadata was added, tried updating metadata with app with no success. Yet, when I used Windows Media Player to rip onto MP3 for the car, metadata was found.
Does anyone know why Naim takes so long to add metadata to new releases?
BTW, I was pleasantly surprised some month back when I compared a Star rip to a Windows Media player rip at how much better the Naim WAV file sounded.
It’s not how long Naim take to add metadata because they don’t do that at all. The Star and Core use commercial metadata services, the main one of which is Rovi. There wasn’t any metadata there because the publisher of that recording hasn’t added it to the Rovi database yet (at least not against that pressing identity). Presumably Windows uses a different metadata service.
Given the number of releases of all the bands that there are globally it seems obvious that it is a major undertaking and some time will elapse before the various meta-data sources are updated. To lay the blame for this taking a while at Naim’s door seems a little…entitled?
This is not unique to Naim. I have ripped many CD on day of release and the cddb has not even known what it was. Roon has much the same issues. But this will auto populate at a time when the data does become available.
There are only a small handful of online metadata lookup services out there. Naim subscribe to three of them in order to retrieve metadata when you rip a CD, and there will always be the odd occasion when a new CD has not yet found it’s way onto a database. Give it a few weeks and it will probably be added. If not, you can always add it manually yourself.
I had exactly the same problem with this album - saw that it had no metadata on my Core, so ripped it using DB Poweramp on the PC (from memory it used FreeDB as a source). As pointed out, there’s a small number of metadata sources, and it seems reasonable with the ones that Naim has chosen.
The bit that I’m grumpy about is that the current Core OS will record your manual metadata changes, but doesn’t reflect the changes in the file or folder names (which was one thing that the UnitiServe did well). This means that you end up with folders with random folder names and file names - making them useless for indexing by other services such as Roon. It’s a pretty major shortcoming which I hope is on a backlog for fixing soon.
