New speakers for Atom
I’m considering moving my current n-sats n-sub to a new system and am looking for suggestions for speakers to connect to a Uniti Atom. A key feature I’m looking for is the ability to mount them on a wall, as I currently do with my N-Sats.
Any recommendations you have would be greatly appreciated.
I reckon the obvious choice are Neat Iotas. They were designed to be used with all-in-ones like the Atom and they can be fixed to readily available wall brackets, as mine are.
Sound pretty good, too.
Roger
I found that my N-Sats didn’t perform too well with an Atom, and changed to a pair of Shahinian Larcs. A slightly unconventional speaker, perhaps, but they work much better than the N-Sats did. Like most speakers they don’t have a dedicated wall bracket like the N-Sats, although they are very versatile in allowing you to put them on the floor or a stand, and in different orientations.
Alternatively, I do think N-Sats are great speakers if they have a decent source and a reasonably powerful amp. Perhaps keeping them and changing the Atom for a Nova would give them the power they need.
Neat Petite :+1:
IMG_0429
Go on, you know you want to……:innocent:
ATB, J
@Osiris , what about wall brackets :rofl::joy::smiling_face_with_three_hearts:
£150k a pair…… plus fitting & installation :+1:
ATB, J
