This is my humble TV set up, it’s served me well for many years and sounds good to my ears.
I intend to leave the amp and speakers as they are and move the turntable and CD player into the other room that I am preparing for the new equipment.
Can’t wait to listen to some of the recommendations you’ve given me. I tend to be quite impulsive usually so don’t think I’ll wait too long before making my mind up, I’ll know it when I hear it!!
Looking forward to hearing how the audition works out. If you demo streamers you may want to hear both the ND5 XS2 and the NDX 2 on the front end of both systems since you are going to be at the dealer location.
I have always only connected my streamers, ND5 XS, NDX AND NDX 2, using ethernet. There are members who only use wi-fi and report completed satisfaction as well. I have never did a direct comparison.
I will admit that I am bias, possibly due to my age and work experience, and simply believe that a direct connection is the most stable.
Ask the dealer to demo both with wi-fi and ethernet cable while your in the demo room.
Can I ask a question? I presume your blu-ray and TV are connected to the amplifier?
If so , do you have a Digital To Analogue input on either the CD player or amplifier ?
If not , I would suggest a Star , that would offer you , amplification and be able to offer you an upgrade on the sound being produced by your blu-ray and TV?
You have 2,500 records that you will gain so much pleasure from if you buy a really good record player. You will hear things you’ve never heard compared with the last record player you used.
As a fan of records, I’d go for a top class record player and plan to keep it for a long time. Speakers lose a lot of value when bought new, so I’d look to get a pair of speakers you can keep a long time too.
I reckon:
buy record player new
buy speakers new
Both of these deserve listening tests and you can only get that from a dealer.
second hand Supernait 2 + Stageline
Supernait is a great amplifier. Try to buy one less than 5 years old or, if an older one, a unit that’s been serviced within the last few years.
I wouldn’t get a brand new Supernait unless it’s on a very good deal, I’d be reluctant to buy anything in the current ‘classic’ range with as yet unknown new kit due to arrive later in the year. But a used Supernait with a used Stageline would be a great amplifier and phono stage, and easy to upgrade in future if you so desire (and easier to sell and don’t lose value as much as speakers).
Yes my tv and blu ray are connected to the amplifier, not sure about the dac. I stream via chrome cast and get decent sound with Spotify premium. I did sample tidal when I bought my muso on a 3 month free trial and found it to be excellent. I plan on keeping the TV set up as it is and plan on starting from scratch in another room to build a stereo only system. I presume that any streamer I eventually go for will be better with tidal or can you get decent sound via Spotify premium? Thanks
Just a thought… What about a really good headphone amplifier and headphones?
I am fortunate to have a big open room space. I can’t speak therefore from experience but I’d imagine managing the room would be a challenge at that size. Lots of opportunity for echo and stuff that others control using room treatment which is a whole other rabbit warren to negotiate
I’m starting to think this is going to be a lot more tricky than first expected with so many options and different paths to go down. The room size might ultimately play a big part in what I hope to achieve. Does anyone have similar room sizes to this and if so any ideas?
P8 and pre owned sn3 takes you to 6k spent or thereabouts. Add in 500 pounds for a Bluesound node and you have very good sources and amp. That leaves a little more for speakers. Given your room size and description you will need to speak to a dealer for demo and matching the speakers to both your room and the amps capabilities. I have a preference for Spendor so would always start there, but pmc seem to be a good match with Naim as a comparison. If the sn3 works well and you have any funds left ( around 1k) then a better dac to add to the Node will be worth spending on. Obviously this depends on you making the commitment to either rip your cds on the computer, or sign up to a high quality streaming service.
It is a contentious view on here particularly, but I think heavily investing in a system to support old technology is a mistake. Yes, make use of what you have, but think forward to high resolution streaming. It is the future.
One of the downsides of asking on a forum is that you get so many suggestions that you can become like a rabbit in the headlights. A long thin room isn’t ideal but you can still get 150cm between the speakers and 30cm each side. Whatever you do, try them at home first.
For what it’s worth, I bought a whole new system recently. It’s a Nova with PMC twenty5.21i speakers on PMC stands. Retail price is £7,600. If you want vinyl in that room, either use your existing TT or get a Rega 8. If you want to rip the CDs you don’t need a Core, just rip them on your computer to a NAS. It’s easy to do and once you retire you’ll have plenty of time. Or just plug in your existing CDP.
I really wouldn’t get carried away with thoughts of a 282/250, which needs a very good source to sound at its best. You’d be doubling your budget.
Hello, this is my TV and blu-ray player. I feed them into a Naim streamer which means that I take to digital signal to a dedicated audio component and I don’t rely on the on-board audio from my blu-ray or tv, I use the steamer as a DAC
The signal is then fed into my audio system , which is on the other side of the room .
I should say there are some good comments on the thread , all of which would lead you to happier listening, I am trying to suggest ways to have better listening when you are viewing
Based on comments so far I’m thinking that sn3 based system might be the way forward. So many of you think it man enough to do good sources justice. I really do fancy maximising my record collection so will demo RP8 maybe with stage line that will take me to around£7k approx. Leaving &3k for speakers and possibly a streamer. As HH said I am starting to feel like a rabbit in the headlights. Problems are there to solved though it’s a marathon not a sprint
Approximate prices, I acquired a few items for less. I think you could think about going “up” on the TT from a P8 to P10 and “down” on the amp from a SN, if you want to optimise around vinyl.
Are stands and cables in the budget?
Might also be worth fixing the speakers first, given the room dimensions, these small but beautifully made Sonus Fabers look incredible for example
I hadn’t really factored in cost of cables what would be a sensible spend based on my budget. Do dealers tend to give you discount on cables etc based on your spend? I know when I bought my MF Spendor system years ago Lintone audio gave me 10% of my spend back to purchase these!
