I’ve got a NAP 250 DR on order with delivery in February next year. Might also touch on speaker cables, but not sure what to do with that … my Chord Rumour seems to fit quite nicely still.
New speakers in the end will be something for end 2020 or even later
Hoping to be able to buy some kit having sold off so much to pay for renovation project , probably heading down class D route which is far better than it used to be
Ditto - don’t need for a re-tip either. Might look to improving wi-fi coverage in my listening room to get the best from my new Bluesound Node 2i. Great bit of kit for the money. Gonna delve into the world of hi-res for the first time.
Continue to run in the new amp & pre. Have some Super Lumina speaker cable to try out too but I need to move the AV rack and all the bits in it to do so and disturbing the SL2s will be a good time to make sure they’re set up as well possible.
Will be looking into the vinyl side of the system too and them I’m done!
The Fraim is certainly one to watch. Having just built mine up I noticed that the spikes don’t fit in the centre of the cups. It required me undoing everything and realigning the less and rods by a few millimetres then re-tightening.
@Bart
I guess it may not work for every situation, unfortunately in my case I have heard the difference through my crude experiments that they could make.
Difficult to ignore now.
I’ve been cautioned from fellow members not to take a random approach, rightly so…that’s my homework for the 20s!
