Hello everybody,
Nwe to the forum and hifi in general.
I have an old Naim setup Olive hi cap and 250 amp.
I have this setup for 5 years and looking to improve to the max. Would a recap improve sound and bass response ? In comparison to my newer amp, I find the sound a little bit dull and lacking response…
A full service, done by Naim or a Naim approved servicer, should certainly get both items back to performing as good as new. A Hicap in need of a service tends to make the pre-amp sound a bit slow and leaden. With a NAP250, being a fully regulated amplifier, servicing every 10 years or so is a must as performance drops off sharply once components begin to drift out of spec.
n.b. Note that a full service is much more than just a “re-cap”.
FWIW, I had my olive Hicap and 250 serviced a few years ago - after over 15 years. It was only after they came back that it was obvious how needed it had gradually become - they were cleaner, more dynamic, not increasingly dull at low volume or a bit scratchy at properly high volume.
Thank tou for your response. Yes, I guess this setup has not been services for at least 15 years ( if not more) I guess, I should hear a big difference after a complete service. I live in Luxembourg and I think the nearest service centrr would be netherlands? Anybody an address?
By the way , what should be done for servicing such a unit? Do you think it is worth doing, compared to what new amps offer for the money?
I have a Linn LP12 ( just fulky restored by authorized dealer) and proac bookshelves… bit willing to upgrade to flooringstanding speakers ( suggestions welcome )
It’s a great system. Out-performing the good-as-new version of those that you will get after a service would mean spending a packet - and a lot more than the cost of the service.
Just another question, concerning my setup: I will be moving to a new house shortly and speakers will be 15 meters away from the amp. I understand from what I have read here that this is a good thing? But, only if you use the right cable (naim ac5?)… I initially planned on buying standart speaker cable, as I will not have the budget for 15 meters of AC5… will it really hurt the sound ? Could I even harm the amp? The cable I am i stalling is audioquest split sb 16/2…
15 meters of NACA5 will sound great. Naim recommend up to 20m. If you can’t afford NACA5 then best go for something of similar low capacitance/moderately high inductance. The Audioquest SLiP cable you mention is referred to by the manufacturer as having a “low-Inductance Spiral Geometry” which sounds like it’s likely far from ideal for your NAP250.
Richard is giving you very good advise, I think that you will be surprised how good your system will sound if you get your pre, power and Hi-cap serviced, and purchase Naim NacA5 Speaker cable, your sound will come alive.
