Hi I am thinking of getting a Technics turntable to hook up to my Naim Uniti 2. The turntable has a built in phono stage but I’ve realised the Uniti has no earth connector. Any solution - possibly loosen a chassis screw and connect it there? Thanks!
Is it the SL1500C you’re thinking of buying ?
If so then you don’t need to use the phono earth cable when using the built in phono stage.
Yes it is James. Ok thanks!
