There’s plenty of slack on the Van Damme 4mm UP-LCOFC Shotgun cable and its not tugging on the connectors.
Van Damme is nice and flexible so I’d not been too worried. Stiff A5 without SA8 plugs is a different matter !
Every little helps especially on a PCB thats 32 years old
Yep - got to look after the classics.
It sounds mighty fine too especially with a Qutest feeding the tunes and SL2s on the end.
That’s an interesting setup. I do keep an eye out for a Nait 2. Don’t really need one but if the right one came up…
