No service currently of DR products
I called my local Naim Audio retailer today to get my NAP500DR and PS500 booked in for service. I asked him to check when it could be done before I took the units into the shop.
A few hours later he called back to advise that Naim Audio Service Department wasn’t servicing any DR units currently owing to parts shortages.
This came as a surprise. I knew that DR upgrades had been ceased owing to parts shortage, but hadn’t realised this extended to service of existing DR units. Has anyone else had this message? If you were planning a service of a DR unit, I guess you’ll be waiting too.
That’s very strange when you consider DR stands for Discrete Regulator.
There is nothing but capacitors, resistors, diodes and a transistor. If any of the parts become obsolete, it won’t be hard to find a replacement.
It specific integrated circuits where used it may be a feasible explanation, but there aren’t. :thinking:
I believe that’s why the Supernait 3 was abruptly discontinued.
They said they would keep some parts in stock to cover warranties etc rather than sell out with no support. :thinking:
@NeilS can you give the forum your perspective, as my units are near service. And yet the 500 is still being built to order?
I wonder if this has anything to due in part of the global memory shortage driven by massive AI datacenter demand, shifting manufacturing from other components and impacting supply chains.
Hmm, my SuperCapDR is in need of a service and there is nothing but tumbleweed from Sheffield.
Not too sure - my focus has been elsewhere of late. I believe there may be a shortage currently, although I thought it was affecting DR power supply servicing.
I’ll look into it next week.
Neil.
I had my nap 300 and 555ps DR serviced last summer but had to wait a month to send it via my retailer due to parts not being available. It was serviced a month later and took about a week. Ask again in a couple of weeks and it might be different. Always good to check with your retailer first to minimise the length of time your kit is away.
I am surprised this thread is so quiet. I hope it’s only a very temporary thing, if not it’s quite a disaster. I have my 555 dr to service in one year or two. If it’s permanent, then I will have to sell my Nds and twin ps.
From what I gather it’s just temporary. I’ll try to get some more info though to clarify.
I hope this is a temporary glitch as well, my 250 DR will need a service in the next year or so. Then 2 HiCap DR’s the year after.
Hope it’s not a subtle way of discontinuing repairs and servicing to only cover warranties like most manufacturers.
I moved to Naim to avoid such a dilemma having had to write of 2 Linn systems due to no support. :hot_face:
Lets hope it is not. Like you, I buy naim for its maintainability. It sounds like a component or number of components are either in short supply, or their supplier(s) is trying it on with a price hike. Either way, not ideal. Im sure naim already have more than one supplier for each component, but if they dont……..be prepared to be screwed. An equivalent supplier needs to be found pronto.
The tell-tale would be the demise of the 5 year extended warranty…..
ATB, J
…just signed up for that with the CD5Si…
This does not sound good. Will wait for the latest update to decide if I need to trade in the 282/250DR/HicapDR for some cables.
Hi Richard, Is it likely the DR upgrade service will resume? My circa 2001 boxes were serviced in 2017 before I bought them so was not worth it and then both the service and upgrade had to be done. Been content though.
Phil
My guess would be that all DR modules are allocated for production of the new products.
Hi
Or mothballed to satisfy warranties. :thinking:
