Hi
My Nac272 both digital coax input gives no Sound when I connect a digital source to it. But the BNC is ok
I’m confused. First time I used the digital coax inputs.’
The inputs are set to enabled
Is my Nac272 really defect ?? Or
Hi
I take it you are switching the input to Dig 2 or 3 - BNC is Dig 1.
I know
I have tried … with no result
I have talen OFF the chassis. The soldering seems to be ok
It could be a poor fitting or faulty coaxial lead. I have a couple where I can put a little light pressure on the RCA phono jack into the DAC and I lose signal. Just one more reason why BNC is so much better.
