My system (cd555,552,500 all DR,Kudos 808) had been unplugged for the last 5 months.Now back from holiday (I know it’s a long one) connected all cables up,played a CD but no sound.
CD—all connections OK .Output selected to Din ( O ).
Pre-amp— Din plug goes to input 1,mute off.
Power amp Din/XLR,red goes to right and green to left,speakers cables OK.
Speakers—connection,polarity,jumper cables all OK.
P/S when I first switched system on I rotate volume knob (with a remote) from min.to max.a few times (and that’s before power amp was switched on) to clean the contacts.It’s the first time such a thing has happen.All connections seem alright to me,so any help to bring sound back would be greatly appreciated.
Thanks in advance.
After so long unpowered check whether the pre-amp has gone back to default settings. Default setting for Input 1 is no connection. Default for input 2 is CD (see the manual for the rest). Try plugging your CD player into input 2, and select CD - remember to make sure the pre-amp is off or muted when you plug and unplug though!
When viewed from the rear? If it’s red on the right from the front there’s your problem.
Done that and to say I am over the moon is an under statement (it literally brought tears to my eyes) when I heard music appearing from the speakers.All is well now and thank you Richard so so much.
