Could anyone suggest a Naim dealer in the Nottingham area now that the shop I have used for years seems to have stopped trading.
Many thanks.
There is Castle Sound and vision on Maid Marion Way or, if you want to go a bit further, there is Cymbiosis in Leicestershire which comes highly recommended.
Kind regards
PB
It appears Nottingham HiFi we’re linked with Superfi (both companies were owned by Eddy’s of Nottingham) so it appears the demise of the larger chain has bought about the closure of the more specialist (Nottingham HiFi) one.
Which is a shame as it was them that got me started on my Naim journey about 6 years ago and they had very helpful and informative staff.
If you fancy a trip to Peterborough, Analogue Seduction are good.
Moorgate Acoustics in Sheffield are excellent for Naim and more, and less than an hour from Nottingham. Easy to reach on the Chesterfield Road.
Can certainly recommend Moorgate, Nothing to much trouble
And Moorgate also has Class A shar8ngnthe pre,uses, so servix8ng available while you wait.
