Hi first post here. I have had a Nova for 3 months. I have noticed a very low level humming g sound from the unit. It sounds like a transformer type hum. Once music playing you can’t hear it. Is this standard for the device? Thanks
Hi Marineboy
I suggest a quick search of the forum will give you the answers your require.
https://community.naimaudio.com/t/question-re-dreaded-hum/6091
Welcome to the forum Marineboy, yes its 99% for sure transformer hum.
All my units hum to some extent, I only hear it when the room is dead quiet & when near to the rack.
Thanks for the quick reply, okay in some way makes me feel better. Cheers
