Ive just purchased the Nova which I am very happy with. I do have one problem though if someone can help. I have a Samsung TV QE55Q85 which is only a year and a half old. I want to pair it with the Nova to play the tv sound through my speakers. It pairs ok via Bluetooth but no sound comes through. I have paired the tv with my Muso without any problems so really not sure what the problem is. Any help would be greatly appreciated.
The Nova should take a signal from the TV via HDMI as long as you use an HDMI ARC port and set the TV to output PCM stereo. However, TV manufacturers are notoriously lax about sticking to the HDMI standard, so it doesn’t always work as well as it should. In this case an optical cable is the best option.
I would love to but I can’t get the HDMI cable from the nova to the TV. I’m in a really old cottage so cant get the cable across the room without major work.
I thought as I could Bluetooth from the Samsung to the Muso it would be the same but yes you could be right that the nova does it the other way. Sorry quite new to this kind of equipment.
