Thinking about getting these for my Nova + SF Venere 3.0’s.
Is there a new cable due out? when?
Yes it’s the Witch Hat Spectre, it’s been trialled with existing customers , some of whom have reported it on this forum.
Price unknown, quality better than Phantoms .
If you go to the Q button in the top corner , you should be able to find the thread
Read the post you’re talking about and it sounds amazing but I imagine its not a replacement but a higher tier cable at a (significantly) higher price point.
Exactly , and I wonder with a Nova that you get the best with it.
The general rule of thumb is that cables should be 10-15% of the item .
In the case of my Nova I have gone to just under 20% with the Witch Hat & Powerline.
Certainly if I had higher end equipment I would happily disappear into the Spectre, higher end Tellurium or Chord speaker cables.
It’s a fine balance
