I wonder…
how come Naim manages to build this stellar product, sells it for 5k EUR and then the screen freezes like it’s Win 3.11.
I have had my Nova for a bit over a month now, everything works flawlessly and sounds great no matter what the source but my screen must have frozen about 10 times since I have it (usually on the home screen).
Everything continues to work well but the screen stays frozen until I reboot it.
Anybody else having this issue or don’t you bother?
I posted this in the other screen freeze’ threads as well:
A possible work-around:
My Nova seems to get ‘stuck’/freeze on the home screen when I switch to the ‘internet radio’ input from a ‘chromecast’ input.
Although a cycle through ‘deep sleep’ (long hold of the standby button) would usually fix it, I stumbled on an easier way to ‘unfreeze’ the screen.
With my remote, I tap the ‘up arrow’ so that it highlights ‘home’ at the top of the Nova screen. I then tap the center ‘enter’, then ‘return’, and finally the ‘down arrow’ to the main home screen. Voila, the screen is working again and will display whatever is currently streaming.
I is probably a firmware or display driver bug that should be fixed in the next firmware update.
