I have a question, still being fairly new to Naim. I have a Uniti Nova as my daily driver, but also have a Hi cap/282 & 250 non DR on loan. Wondering if it is possible to use the Nova as just a dedicated streamer with the 282 & 250 ? And if so, how do you accomplish this ? Thanks
The Nova has a pre out, not a line out. Ideal for a power amp like your 250. If you connect the 282, you will be putting the signal through two preamps and two volume controls. Not ideal, but it would still work.
