Just want to add that the 250DR will also work well for a long long time to come and one can also run the NSC222 into that. The power amp won’t be blocker for future upgrades, rather the streaming sections. There is quite a cost gap between new 250 and the 250DR’s that are available on the market at the moment.
That is the nature of forum questions there, you will get many answers. At the end of the day let your ears lead the way. Use the forum info to create a shortlist of things to go listen to. Do not just buy wildly without listening to it first, especially when doing something outside of the normal upgrade path of Naim. Go for a demo, it should instantly make you want to part with your money, otherwise don’t do it.
And keep in mind the Atom HE is the only Uniti that was designed as a standalone pre-amp.
Thank you
