Nova with Dali Rubikore 2
Hey guys, what do you think, do the Dali Rubikore 2 speakers go well with the Naim Nova? Is anyone currently using these Dali speakers in their Naim setup?
Thanks and cheers
The Nova will work with many speakers but it’s really how the speaker interacts with your room that is key.
Room size, listening position, etc. all
come into play!
To answer your question a nova will
drive them with no problem but ideally you would demo them and try a few other brands too and of course with a stand mount speaker getting good stands is worthwhile.
If you have a local dealer that’s a good starting point.
I had a Nova with Dali rubikon 8 and it was a perfect combination.
