NPX300 (to add to NSC222 or not)
It’s enough using one of these and remove the rubber band from the tool itself just using the rubber band. Then you won’t use too much force but the added grip will be enough to remove or secure it. Steve sells recommended it one time.
Around 10-15EUR on Amazon.
Just using the rubber band, how does that help?
Using John Mcenroe language “You cannot be serious” about Steve Sells recommending this :slight_smile:
I am planning on using some gloves so that i can apply more force while protecting the fingers.
ok, i get it, the added grip could help. i will try the gloves to have the same effect.
The problem is lack of grip. Not force you can apply with your hand. You wrap the rubber band around the burndy metal part and done without excessive force.
If I had problems with the Burndy latching rings, this would be my first choice. We have a couple and they’re great for all sorts of things (stuck jar lids, etc.). Every home should have a pair.
I asked Naim support and they advise the same as you: 222-gap-250-gap-300.
Because of having the 222 power supply as far away as possible.
And from the Stereophile review…….
“The supplied electronics were laid out on the rack in a sequence that helped to maximize sound quality. At the top was the NSC 222 streamer-preamp, with a gap below. Then came the NAP 250 stereo power amplifier, another gap, and finally the NPX 300 power supply.”
Furthermore…….
“…..the inherent quality was high enough to clearly hear the advantage of Naim’s Super Lumina”
ATB, J
I left the burndies and npx300 alone, so that they could relax/burn in.
The sound is now getting better and better. The speakers needed to breathe a little more; more space from the back wall and between them, very small distances, yet fundamental.
Being a streaming late adopter, i realize how this is a “crazy new world”.
I have 3 meters BJC 6, BJC 6a and Catsnake 6a, all tested between the Core and Router.
I also have 25 meters bjc cat6 between the router and nsc 222, and no switches.
With 222-250 the order of preference was 1)BJC 6 2)BJC 6a 3)Catsnake 6a; 3) was not acceptable, slow and congested.
Now, with the 222-300-250, the order is reversed with 3) being vastly superior to 2) and 1).
The benefits the catsnake brought, are as big as the npx300 upgrade itself.
In fact, some of the benefits i was expecting the npx300 to bring, only happened when using the catsnake. Previously, the catsnake put a veil in the sound, now it removed a big veil.
It is really stange, the catsnake from cold, not being used for more than 2 months, sounded so much better.
