Can you see the Downloads folder? If it’s just the contents that are missing, you probably need to rescan using the DTC, and possibly refresh the UPnP cache on the app.
I can see the downloads directory with all the music in it, and i can also see the music folder which has all my rips from my computer, but only the rips are viewable in the naim app when I use Upnp for the muso. I cant seem to find it in DCT anywhere I look, nothing relating to a downloads folder, I’ve refreshed the NS01 cache to see what that might do.
I don’t know the NS01 but as it’s obviously not indexing the downloads folder, I suggest you use the DTC to make sure that the folder is listed as “active” or some such word because I remember my Unitiserve stopped indexing the downloads folder after I had inadvertently changed it to something else.
Best
If you can’t see the downloads share in DTC, click on Scannable Network Shares*, click Add. Then enter \\127.0.0.1\Downloads and click Ok.
*That’s off the top of my head, as I don’t have a unit in front of me!
