Ns01 stopped working but time is fine in bios
I sold my old trusted ns01 on to one of my friends some time ago. It worked fine until one day there was a short unwanted loss of power. After that the ns01 has stopped working. It runs fine we can get into bias and the time is still the correct 2026 time, so the cmos battery should be fine. But it does not start up and we fear that the HD inside has stopped working. Is there anything else we can try before giving up on this ancient computer.
If it is the OS on the HDD then I think you are SOL. This was a “factory-only” repair back in the day. Many have tried cloning the drive but I’m not aware of any successes.
Probably worth asking @NeilS whether he has any ideas.
In case he doesn’t respond, and assuming that the NS01 is similar to Unitiserve and HDX, when you are in the BIOS, you should check that it has loaded the Naim Default BIOS. And I would put a new CMOS battery in there as well, in case it’s poised at some level which loses some BIOS settings but keeps the clock active. I am guessing it’s a CR2032 battery which your friend will be able to get easily for little money.
I think you’re correct about the CMOS battery condition, as the time setting has been retained.
Worth trying a Naim defaults in the BIOS.
If the VGA output hangs on a black screen, that would indicate that the operating system is corrupt. If it hangs on the Naim disc, the services can’t start.
Whether the corruption is due to the power outage or disc failure, will require running some diagnostics.
Neil.
