Nsc 200 + npx 300
I looked for an answer but I figured someone here would know. If one is using NSC 222 with the NPX 300 is there only ONE main power cable needed from NPX to wall? And then all other power cables come from NPX to NSC?
Presumably you mean NSC222? The 300 powers all of it, so when using it you remove the 222 mains cable.
Thanks @ChrisSU. And I fixed the model number.
@opus I think you also need to edit your thread title.
What should it be?
