I want to get a NSC222 to drive some ATC active speakers - the sound was amazing.
However I also want to play CDs - I know, I own about 700 or so.
The question arises will a NSC222 control a CD5Si - to play or stop?
I appreciate that they are different generation of product, but Naim has yet to do a new CD player and I suspect, sadly, that are not planning to.
So my aspiration is a 2box system DAC/streamer with a CD player.
thank you - I did wonder if there was a remote link or indeed if anyone else had addressed the issue to end up with a single unified remote and 2 generations of Naim kit on the same stand.
I had a 272, and through system automation and the Naïm app, it could control my CD5 XS. I moved on to the 222, and can confirm there is no longer any automation between both boxes.
Unless you intend to stream music from one of the streaming services, then why buy a streamer?
Otherwise if you do intend to stream from on-line, then best to buy a cheap disc drive, link to a computer and rip once. Copy the files to usb drive and stream from that. CDs boxed away.
This is really a question for a good dealer to talk through options.
Thank you for your reply, we have two different use cases, my partner streams lots of music from young bands - I tend to play CDs - and phono.
I really want something that does both/ all three. Linn do a great box, phono input and digital but nothing native, same for Naim except uniti -
A great two or three box solution would be perfect
