Morning all.
I have on home dem a nsc222/250 which I picked up yesterday evening.
I have it set up to never go into standby but to be permanently on.
When I play a single track and it finishes I get play queue showing on the screen but I don’t have queued music.This happens on tidal and Qobuz.
Also I can only get the album art showing while playing but I would like the track/album information showing.
I can get it to show by pressing a button on the remote but it goes back to the album art after a couple of seconds.
Am I missing something in settings or is this how it works.
I can of course contact my dealer and ask these questions tomorrow but I’m hoping I can get an answer on here and hopefully rectify what’s annoying me while I sit and listen today.
This is what my 222 does so I just live with it!
Ok,cheers,thanks for the clarification.
I don’t bother too much with the screen. I have it switch off after selecting music to play. Happy using my iPad for display of info.
I’m another that keeps the display disabled during playback. If I want track or album info I’ll look at the app.
They handle also a single track from some sources as a play queue.
Behavior is like: put selected track(s) into queue (starts with the first one selected), then play the queue.
Showing you have a play queue indicates, that on those inputs you can press play, and it will repeat whatever queue you played last.
(Without anything queued, you’ll first have to select something, before “play” has any effect.)
