NSC222 Vs XS2 (pre) and ND5-XS2 to drive a NAP300DR
Hello all,
I am new in this community, although I bought my Naim Nait 1 in late '84 together with my Sondek (still using it a little bit upgraded along the time).
I guess my question may seem a little confusing, so let me explain:
'till october my setup was:
sondek-ittok-goldring+stageline, ND5-XS2, NaitXS2+TeddyCapSE, Harbeth7
Last october I had the chance to buy a woderful NAP300DR (used) to overcome my NAIT XS2
now the setup is:
sondek-ittok-goldring+stageline, ND5-XS2, NaitXS2 (using PRE-OUT)+TeddyCapSE, NAP300DR, Harbeth7
Obviously this has been done because I had no money enough to by also a NAC252 and a Supercap… :grimacing: , although I have to say that the ā€œfrankenstainā€ plays nicely!
Finally my question to you:
Can it be a good idea to replace (at least) three pieces (NaitXS2, ND5-XS2 and the TeddyCAPSE) with a NSC222? It has the phono input, so maybe also the Stageline can be removed from the chain…
Could it be worthwile? Any suggestion?
Thank you in advance,
Edo
If you can get a NSC222 it will cut your box count down - and I think you might get a good trade in on the pieces .
Welcome to the forum :slight_smile:
I’d have thought that would be pretty sensible! I suspect there are different options with combinations of used kit that might also be suggested, but the NSC222, to consolidate in a single box the pre you’re using the XS2 for and the streamer you’re using the ND5 XS2 for, seems perfect. I’m sure it stands a very good chance of sounding better than your current setup as well.
You may want to consider staying in the used market and with the possiblility of picking up a NDX 2, NAC 282 with a HiCapDR to put out front of your NAP 300DR.
If you go the NSC222 route you should be able to find a dealer that could help you demo with the 300 prior to purchase.
I’d get a 252 supercap dr, these now cost less than a 222. Sell the xs2 and nd5 and get an ndx2 when funds allow
I agree. If you keep the 300DR a 252 and SC is a much better match
Agree, more boxes better sound
Always mate, always
A dealer said to me that the Stageline has an edge over the NSC222 phono stage. If you are an avid player of records, I would look for a different upgrade path. Speak to your local dealer and listen to different combinations. I have a 282/250DR a Topping D90LE as a Roon endpoint, a Pink Triangle/RB300/Dynavector 10x5 going into a stageline. The sound is sublime, a 300DR has appeared at a good price, I am tempted, very tempted!
I am always doubtly with this concept: more boxes more sound… of course splitting high tension with low tension is obviously better (the same for ac and dc signals); but adding more boxes means more connections, more plugs, more soldering, more copper wires subjected to EM interferences, more matching issues… I mean it is absolutely true? Or ā€œonlyā€ if you have supercables, a faraday-cage room and no wife-set boundary-conditions…? :upside_down_face:
Anyway, Thant you all for your great suggestions; as always it happens, I am more confused than before… but this is the beauty of this passion… isn’t it?
You do very much have to pay attention to cables, but in my experience a ā€˜box upgrade’ is ALWAYS quite big, even with standard Naim cables (which are well made). Fancy cables CAN add a further uplift but tend to change the sound a bit as well so need careful audition.
Preamp being presumably of major consideration, you are looking at basically replacing a preamp that’s inside the XS2 with the one in the 222, the difference between both in terms of SQ might not be that large, if any, mostly likely you will receive a difference in sound sig, not an uplift in SQ IMO. Both preamps are not meant to be competing against a separate preamp, which the NAP300DR deserves.
That said, the 252/SC suggestion is the most appropriate one, anything less than that will work, but will be a compromise. Basically the choices are down to the following two, the second one seems way more balanced, you are not looking for reducing box count, so not relevant for the comparison.
222/300DR
ND5XS2/252/SC/300DR
There’s a lot of advice to go used and optimise the pre here. More than I thought considering the 272/300 had advocates on here at the time they were contemporary options.
I know the 222 and 300 are different eras, but is literally everyone recommending something other than that combination?
In Naim world as a general rule you tend to find that a better pre vs power amp combo will out-perform the obverse. As you already have a 300DR this might be challenging without spending a lot or going for second-hand.
A 252 would be the obvious choice but with an eye to the future a 333 might be a good alternative.
You could trade the whole lot and go 222, 300 with NC 250???
