Hi has anyone added power supplies to 333/332 and what was your experience, Thanks for any advice running ATC40a loudspeakers, may eventually end up with the 50s as an end game
You can see some of what you want by searching in the forum. Try using NPX300 as the search term.
If you are only going to add one NPX300 put it on the 333. But as David said, their are at least 2 threads about this subject with multiple posts about the benefits of adding the power supplies to 300 series products.
See the thread on @Dan_M ’s Naim factory visit perhaps.?
The benefits of adding the PS were clearly demonstrated. The consensus advice was that adding the PS on streamer instead of preamp was more satisfactory, if the streamer is the only source. However, for the full effect, just have two 300s…
Going against the grain here, but I prefer a single 300 on the 332, and by some margin. Try both of course. The 333 is immensely capable and the better pre lets you hear this. I’m running balanced all the way to active PMCs.
Enjoy the experiment.
Will likely get one for each at this stage seems to help 332 more from comments I have seen
I’ll have a second 300 incoming soon enough too. Very much the icing on an already very accomplished cake.
Looking forward to hearing them on the ATCs
