Yes, apologies, power supply cable as per the website page shown.
However, the manual as you show it appears to also include the interconnect, which is a bit confusing. Probably best to get clarification from Naim here.
Clearly it would originally be supplied with everything that’s marked as ‘in the box’. The key thing is whether it was sold ‘with all original accessories’ or ‘sold as seen’. If the former, and they won’t supply the lead, the options are to return it, or to buy the lead, if the price for the NVC was sufficiently low they you can suck it up.
No you are not. When I bought mine, more than 2 years ago, both cables where supplied.They are a standard 5 pin din and a 8 pin din to power the unit from a nsc 222 or nac 332
When items are sold on something like Ebay, if the auction doesn’t include accessories that were originally supplied with item, it is usual to describe as.
Auction does not include X, y or z.
Or. Auction only includes items shown in photos.
What did the description say.
Anything like Complete with accessories, box and packaging.
You bought it secondhand, so the seller isn’t required to sell it with the original packaging.
However, they could have made that clear in their listing.
If it is the one that sold on 10/5/26, then that is exactly what it says. Which is unfortunate because if it had said Complete with all accessories, there would be a reason to send it back.
Obviously the OP already has a 5 pin Din, otherwise it would be unusable. My thoughts on this is just enjoy the phono stage and put it down to experience.
