Not AIFF but yes to wav v flac. I used db poweramp, transferred files to my usb drive that is plugged in to the router. Wifi from there to the Auralic Aries. I can not hear a difference between the flac and wav whether played native or resampled. I can still hear a difference with the Amazon streamed file on the Bob Seger, definitely a more open sound.
It isn’t any kind of a major difference, and it is not a problem, more an unexpected benefit of Amazon HD streaming.
I have now, after a few weeks of having the Sirius in the Auralic path, decided to run permanently with DSD 256 resampling enabled. I find no downsides and the sound quality seems to me to be all I expect from a well set up system. it has all the separation, sound stage positioning in three dimensions, and clarity from the deepest bass to the toppy est treble. Unlike the Chord Qutest, which is a fine piece of kit, I haven’t had to dial back the top end with a filter. I’m running in precise mode on the Aries before running the source file through the Sirius and Vega.
