I have an all Olive 82 + Hicap + 250.
Can I use any of the 2 middle output sockets (2 or 3 ) on the rear of the Hicap to connect to the 250?
You can use either as they are daisy chained, from a L&R audio perspective, from Socket 4.
The 82 should be connected to Hicap socket 4 so use the closest socket, which will be 3, to connect to the 250.
Thanks James.
