Olive Active Connection Question
Hello all. I have an 82, two 250s, two HICAPS and a SNAXO and I just acquired a third HICAP. What is the best way to connect the three HICAPS? With two I had them connected together and then to the 82 with the link plug fitted - can I change this? If not, should I just connect the third HICAP to the 82 as well with the link plug removed? If yes, do I still need the NAPSC connected? Any guidance would be greatly appreciated. Thank you very much in advance.
Assuming you are already running active, with one Hicap powering the 82 and the other the Snaxo, it’s just a matter of removing the remaining link plug on the 82 and connecting to socket 4 of the third Hicap.
It’s best to have the two best matched Hicaps on the 82. You still need the Napsc or it won’t work.
Thank you very much for the quick response. That’s what I thought but wanted to confirm and confer first. I’ll do it now. Thanks again.
Let us know the outcome . And your opinions .
Hopefully its worked out and being an improvement. But dont despair if it goes backward .It will just be mismatched hicap syndrome.
