Apologies if this is old ground; the LED has gone in my Olive 250 - any idea where I can get a replacement?
A Naim dealer may be able to check and replace if possible.
You mean the Naim logo…?
A (good) Naim dealer should be able to sort that out.
Failing that, its back to Salisbury - or to Class A…
The illuminated Logo on one of my Hi Caps went very dim.
It had got to the point where it needed a service, so I asked Naim to fix it at the same time. Fine now
Many thanks for the input. I don’t suppose there’s somewhere you can buy the LED from direct?
No, it may be something that could bee done by a dealer like Grahams etc., otherwise it will need to go to Naim or Class A. VFM-wise it’s probably something best done as part of a full service.
No, those bulbs are for Chrome Bumper kit.
