Olive NAC 102 + HiCap with Chrome Bumper NAP 250 – Good Match?
everyone,
I’m currently using a Naim Olive NAC 102, HiCap, NAPSC and NAP 180.
I’m considering replacing my NAP 180 with a 1985 Chrome Bumper NAP 250.
Would the Chrome Bumper NAP 250 be a good match with my Olive NAC 102 and HiCap?
Has anyone tried this combination? I’d appreciate your thoughts and experiences.
Thanks!
I don’t know your speakers, but a 250 is rarely a bad decision. Definitely check the service history though and factor that in to the cost if needed. Makes a big difference. Ditto your Hcap if necessary
Make sure you are using a suitable speaker cable too, A5 is the obvious choice.
72/HiCap/250 would be a classic olive Naim system, but the 102 should be a decent match too.
Bruce
I had the same amplifier as you and was advised to change to an 82 before thinking of a 250, so that is what I did. I later swapped the 180 for a 250. The change to the 82 was far more beneficial than the change to the 250.
Im with Mr H on this topic
Martin
We had a 102 with CB hicap and NAPSC, changed from 200 to 250DR, and this was sourced by CDX/XPS combo.
Recently moved from 102 to 282, and in hindsight although the 102/250DR worked it was too much in your face as a combo especially driving Intro 1
So I would advise changing up pre amp first, we were gobsmacked at the difference
Another vote for the pre-amp upgrade. I went from a NAC102, powered by my NAP180, to a NAC82 + HiCap (so, admittedly, a double jump). The improvement was enormous. I later replaced the 180 with a NC250 and, although clearly a better amp, it’s not a night and day difference. I think you’ll get a more noticeable improvement upgrading your pre-amp than you will by changing your power-amp.
Also, don’t forget servicing. If you’ve had your present kit for a long time, your ears have probably adjusted to the degradation that creeps in. I had my 102/180 serviced after owning them for about 20 years and the difference was startling.
