There is a hum present regardless of input selection on my 5si which increases with volume to such an extent that it is quite noticeable at decent listening volumes.
The turntable ground is connected to the phono stage ground but still the hum is present.
Any bright ideas? There is nothing on top of the amp but there is a Sky+ box on the shelf adjacent to it.
Perhaps you have a ground loop which can happen if more than one grounded source is connected to the amp?
Also, is anything connected to the HDD output?
