Good morning
Only one channel comes out of my CDS3.
What may have happened?
Thank you
Connected with DIN?
Tried other cables?
Is it the same whether via DIN or via RCA? Have you tried different inputs on your pre-amp?
Could be one of the DAC’s failing, this happened to mine.
si
purtroppo si
Ok, it sounds like it will need to be looked at by a Naim servicer. Contact your dealer or else your distributor.
Italy?
si
I have already contacted my dealer. Thank you
I had very good experience with LASA in Piacenza. They are a Naim approved Service Centre.
