Oppo Blu-ray player region code selection has stopped
I spent an hour or two tearing my hair out yesterday as I was trying to play a Region A locked disc on my multi-region modified Oppo blu-ray player without success. Usually to change the region code playback you just wake from standby using one of the numerical keys on the remote keypad - 1 for region A, 2 for region B. However, it no longer wakes from the keypad and hence I can no longer switch region. I have unplugged and re-plugged, cleared the blu-ray live cache, tried switching remote channels, but to no avail.
I do recall at some point the remote stopped working and I solved the problem by switching the remote from channel 1 to channel 2 which restored full service. I wonder whether this has something to do with it (switching back to channel 1 does nothing - no functions work).
Has anybody else on here come across such an issue or have any better ideas as to how to solve it? Thanks!
For devices without any physical user interface, eg tv’s and bd players, I always purchase a spare, original, remote asap……. not that this helps on this occasion. Perhaps a quick search on t’bay for a spare remote might be worth a try……?
Best of luck,
ATB, J
PS your player wouldn’t have happened to have done a sneaky ota firmware update?
I hope note. I have specifically not had it connected to the 'net to avoid this…
Hi Richard - I think they ceased the updates many years ago, as (as you’re probably aware) Oppo no longer make DVD/BRPs, or support them, much to the annoyance of many.
My remote ceased to operate a while back. The handset seems OK vis I can see a red light against a mirror, but the player doesn’t respond. I’ve tried an IR receiver in the back (per the manual), but so far no success. If you get your’s going this way, please do tell how you did it.
I know nothing about OPPO.
but wanted to help do Google AI game me this hope it might help.
“ If your Oppo Blu-ray player’s region-free mod or remote code has stopped working, it is usually because an official firmware update overwrote the mod, or the input sequence was entered too slowly or incorrectly.[1, 2]
Common Fixes and Troubleshooting
  • Check Timing and Sequence: Most software or remote-based region hacks (like DIMMER - DIMMER - DIMMER - MUTE followed by 1, 2, or 3 for UDP models, or specific button combos for older units) must be entered completely within 20 seconds while no disc is in the player. [1]
  • Verify Remote Functionality: If you are using a replacement or universal remote, make sure special commands like DIMMER or PURE AUDIO are registering properly—some third-party remotes require pressing an extra button like SHIFT first. [1]
  • Firmware Overwrites: If you recently updated your player’s official system software, it may have disabled a firmware-based region hack. You may need to re-apply the region-free firmware patch designated for your specific model version. [1, 2]
  • Hardware Mod Check: If your player uses a physical mod chip (such as from JVB Digital or Kerr/Pro kits), a loose internal ribbon cable or a mismatch with a new firmware version can cause the hardware switcher to stop responding. Powering down completely, unplugging the unit for a minute, and retrying can sometimes reset the mod’s microcontroller. [1, 2]
If you can tell me your exact Oppo model number (e.g., BDP-93, BDP-103, UDP-203) and whether it uses a hardware mod chip or a software/remote code, I can give you the precise reset sequence.”
Thanks Skep, I’ve been through all the AI steps already. I’ve even tried a Oneforall remote but it seems the player itself doesn’t recognise code/channel 1 any more and that’s the one that carries the region switch coding…
Sorry Richard.
Hope it gets a fix.
ATB
Two last possibilities then I’m out of my depth. :thinking:
If your Oppo Blu-ray player is not recognising “Channel 1” (often referring to DVD Region 1 or an HDMI Input 1/audio channel connection issue), you can fix it by adjusting the region setting or resetting the input configurations. [1, 2]
Fixing Region 1 DVD/Blu-ray Issues
If you are trying to play a Region 1 DVD or Zone A Blu-ray and the player does not recognise it, the region code may have reset or needs manual entry:
  • Ensure there is no disc in the player and the tray is closed.
  • For DVD Region 1: Press DIMMER, DIMMER, DIMMER, PURE AUDIO, then press 1 on your remote within 20 seconds.
  • For Blu-ray Zone A: Press DIMMER, DIMMER, DIMMER, MUTE, then press 1 on your remote within 20 seconds.
  • Turn the player off and back on to apply the change. [1
To fix an Oppo Blu-ray player that is not recognizing a remote set to Code/Channel 1, you need to re-sync the remote code by ejecting the disc tray and pairing the remote back to Code 1 (or switching the remote’s internal code switch). [1, 2]
Steps to Reset and Re-Sync Your Oppo Remote
  • Eject the tray: Press the OPEN button on the front panel of the Oppo Blu-ray player to open the disc tray. [1]
  • Pair the remote: Point the remote control directly at the front panel of the player. Press and hold the ENTER button on the remote for about 5 seconds. [1]
  • Check the code: Look at the front panel display of the player. It should show the code it just registered (Code 1, Code 2, or Code 3). [1]
  • Change the dip switch if needed: If holding Enter does not work, open the battery compartment on the remote. Locate the small code switch (dip switch) and change its setting to a different channel (such as II or III), then repeat the open-tray and Enter-button pairing process. [1]
  • Drain residual power: If the remote remains unresponsive, take out the batteries. Press and hold every single button on the remote for 3 seconds each to clear any stuck memory state, then insert fresh non-lithium batteries. [1]
Thanks, have tried all of those. I can set the player manually via the menu to Channel 1 or 3 and then use the open-drawer Enter command to then force it back to Channel 2, but I can’t get it to do that for any other channel, hence it only wants to switch to channel 2.
Regarding the remote. Have you checked that it is producing an IR signal, by pointing the IR sender at your phones camera, and you should see a faint red light when you press any button? Presumably if it’s a button issue, you could try opening up the remote and cleaning it with IPA.
Yes, definitely producing a signal. The same issue exists with a OneforAll remote with all the same functions (which should automatically default to channel1), so I’m leaning towards a player fault.
I remember a lot of players that were multi region, you had so many goes at swapping the region so many times, then it would get stuck in that region.
This one has a special chip installed that allows (or rather, I should say allowed) blu-ray region selection.
Hello Skeptical,
a have an Electrocompaniet EMP3, which technically based on an OPPO BDP-103EU. Since around two months it is no longer possible to play european DVDs. Blu-rays are ok. The last firmware is from 2021 and i used it for years without any problems. No firmware-update since 2021.
I called a pepair shop and they told me, it is a problem with the a chip for the codes.
Do you know about these chips and what to do?
Thank you for your answer
Stefan
@Cherry571
Hi
I’m no expert in such things it was just that our Forum Leader @Richard.Dane
Was having an issue and I tried to trawl Google AI to try and source a solution to his problem .
Perhaps he might pop in and give us an update to the outcome.
Sorry I can’t help more than that.
:+1:
The outcome is that it looks like there is a problem with either the machine or the chip. However, it plays Region B discs just fine so…
Glad it’s not a doorstop.
Hoped to help. :+1:
