Just upgraded from ND5XS to ND5XS2 but having issues with the TV sound via optical cable to the new streamer (digital input Toslink)
Nothing has changed settings wise, apart from the streamer … which gives no sound. Interestingly, if I use multiroom via the app and my MuSo, everything crackles, but still no proper audio from the TV.
I’ve even checked the fibre optical cable by plugging it into the Muso asks the TV sound to it works absolutely fine!
The LG TV (C8) sound is set to optical output PCM and the digital input on the new ND5XS2 is enabled.
What am I missing (anything)?
The streamer is 2 days old and I’ve just managed to connect the TV today. Bluetooth connects but ‘stutters’ constantly … whereas my first generation MuSo doesn’t.
I guess I need to return the ND5XS2 and swap it for a replacement unit
Really hope it isn’t a faulty unit and that I’ve missed something in the setup, but I can’t see what else to change. Any ideas?
I’ve done the usual factory resets, power down and deleting the iOS app etc … still the same issue… no TV audio via optical digital input on the ND5XS2 (but works on the MUSo and my previous first generation ND5XS)
