Ok so what do I use…
My 24bit CD player has both RCA and Optical outputs. Which one should I use
A) RCA straight into my Supernait 2
B) Optical straight into my ND5XS2 Streamer and use the Naim App to switch
Many thanks
B
The only sensible answer I can think of is to try it yourself and see how they compare.
You would be comparing the DAC of the CD player versus the DAC in the streamer. Give it a go on both. Only you can judge what you prefer.
Thats what I thought. The CD is the Meridian 506 24bit from the 1980s
How do you find the ND5 XS2 with the SN2 - I’ve wondered how that goes up against the Nova.
It sounds amazing, superb clarity throughout. The SN2 is unbelievable
I will save up for the NDX2 at some point, but for the money, the ND5 does me
B
I had both on my SN2. I had the ND5XS2 on first and now I have the NDX 2.
ND5XS2 sounded a little more raw. A bit more naughty. A wee bit more punchy.
NDX 2 sound more delicate, more refined. The high frequencies are noticeably more filigreed.
Adding a HiCapDR to the SN2 with the NDX2 seemed to push the midband a touch further back so that all the frequencies are a bit more balanced and in-tune with each other.
I’m keen to try this against the Nova in an A/B comparison. Unfortunately, there are no demo units of the new streamers in New Zealand at the moment. There are mixed views on the Forum as to whether the SN2 with a new streamer is a significant improvement on the Nova.
I would not know Mike
All I can say that the sound is amazing. I was thinking about the NOVA myself but was told that I should go with the SN2 and eventually get a streamer…well that didnt take long, a month I believe.
B
