Hi team, I have an original naim uniti from back in the day, like all others I am sure the screen is now totally dead. Not an issue as the app works fine.
However I am certain its set up for small speakers Plus Sub, as thats how I have used it for ages. But now I want to hook a full range pair on it without sub.
Is there are way to factory reset the uniti? I guess that would put it back to normal speaker mode, or can someone give me the exact sequence I need to go through
There is an easy way to do a factory reset of an old streamer without the screen working but I forget what it is. @NeilS knows though! If he doesn’t come along in a few hours, I’m happy to go and write down the key presses for you.
Press & hold “stop” on the front panel while switching the power on, you need to hold it long enough for the unit to boot past the splash screen, so give it 5 to 10 seconds before releasing.
The reset takes a minute or two & should reboot to a connectable state via the default DHCP setting.
The default setting for the speakers is large, but I can’t recall if that’s with or without sub. (Kind of moot anyway).
Neil.
Edit: Tony’s post below has reminded me - you may need to press mute after the long stop, I can’t recall if this is required, but it won’t do any harm to press it anyway.
