Your right they did have a bit that that stuck out guess that’s the spring loaded bit, only problem is that being so low the cables sort of did that for you any way pushing the connector up in the socket.
But I guess if you can get some then ever bit helps, I had 6 off them but let them go when I sold the speakers
