Recently, while checking spikes and Fraim Cups, i found these front screws and washers inside the plinth quite loose.
I tried with with an L shaped hex key to thighten a bit, i assume they have to be retorqued at 2.5nm according to spec sheet and will be a not so easy job tilting the cabinet for easy access.
Is there anything else to look after here ?
Roberto
