Any with p8 or p10 using the dedicated wall mount if so is it any good?
I am currently cheating with this.
Yes I have one with a P10 and it is excellent. Pretty good value too.
Thankyou I’ll order one
Yes i run one with an rp8 very good
Yes I can highly recommend it. Remember to not fully screw it to the wall when affixing. As it is designed to hang off the fixing screws so you can get the best performance out of your baby Naiad . Good luck.
Good to see a Collaro mat - cheap(ish) and worthy swap to the stock mat, not so static inducing either and (to my ears), reduces the noisefloor a tad…
