Hi All
Just bought 2nd hand nait xs-2.
It came with a naim uniti remote control that doesn’t work with amplifier. Only volume works.
How can I pair the remote with the amp?
Thanks in advance
For a NAIT XS you’ll need a Narcom remote of some sort. When new it would have come with either a Narcom 4 or Narcom 5. Maybe the seller got the remotes mixed up - the Nrcaom 5 and the Uniti remote look very similar. Probably worthwhile contacting them.
