Hi
Since the firmware update, Paradise Radio stopped working. Any link between the two ?
Hi Radio Paradise is working for me,try unplugging for a while,sometimes can work,regards Steve.
New report. UK - Saturday 29th
@Stevesky
All the Radio Paradise’s are off line again.
BBC’s Naim, Linn etc are OK
Panic Over - all back on now
Whoops, change that, its off, then intermittent, now off
Same here in the UK
Hi All,
Looks like Radio Paradise are having issues with their servers again. I’ve sanity checked the VTuner / Naim side and all is working on that side.
I’m sure Bill @ Paradise will be on the case soon.
Best
Steve
It all seems OK now, I’ve been playing the Main Mix linked via Naim’s Choice without problems for last 2 hours
I still have issues with RP channels.
What do you mean by ‘channels’ & can you describe the problems.
The different Radio Paradise channels cannot connect.
All are working correctly in UK & I also was talking to someone in South Africa earlier this afternoon & he is connecting OK.
What country are you, I suspect the problem might be with your local server
Sweden
At the same time as reported, I lost mine in Germany. Now seems ok in a hotel at Gatwick Airport
