July 7th and the 14th August then…
Coincidentally the cat on the chair (pic above) is also called Tom.
His sister behind is Shirley. They’re named in honour of two great Welsh songsters.
Really - love your dogs!
Hi @milesF Love the office location, can I ask the make of your laptop table, something I should invest in!
Many Thanks
Gary
It’s the ‘Portable Adjustable Desk’ from a firm called Posturite.
Bought it in 2020 during lockdown but I see they now sell a ‘V2’ model that seems pretty much the same thing.
Thanks for the prompt reply, I will check them out, it’s definitely something that I need to invest in.
Gary
I have a very similar coffee table aka Opium table.
Mine is made from reclaimed teak, it may well be from Indonesia as well.
For the sharp-eyed you can see a 72/Hi/140 driving Epos ES-14. The non-Naim surround only crept in last year.
What’s that record cleaning brush you have on top of your amp stack ? The one that looks like a large shaving brush or make up brush ?
I use it for light dust on every playing surface before dropping the stylus. It’s very effective and causes no static.
For deeper cleaning I have a carbon fibre brush and a Project VCS
Thanks !
