Before i start maybe Richard when he spots this can move this to my closed topic on this, cheers.
Well after many months now owning, using etc the PhoenixNet, i can say that i have been very happy with it, and what it does.
I was Before using the etherregen with a separate power supply, it worked fine, but i just disliked the look, how hot it ran, plus all the added stuff like power supply etc, so sold it all.
Now the reason for this post is, the unit i got was x demo at a fantastic deal, not sure how much use it have had, as even dealer wasn’t sure. Anyway i was running PhoenixNet, then into melco N10, and finally then into my vivaldi upsampler. This i found to give me the best results from the stored music on the melco.
Well after reading the last post on my old thread from mister rooster, a few weeks back i decided to switch things around, as the PhoenixNet will now certainly be burnt in, as the unit does indeed take a very long time to burn in, due to the lovely caps they use in the power supply.
Well i have to say i have been converted to running all through the PhoenixNet, not only has this somehow improved the sound quality of my stored music on the melco, but also streaming from qobuz has slightly been inpoved i feel, now it doesn’t go through the melco.
Anyway it’s all fascinating this stuff, haven’t a clue why it should be different, but it is.
But for anyone trying a PhoenixNet please try it both ways, but make sure it give it plenty of time first, as it certainly didn’t give the same results first time round.
300 hours was mentioned, i can’t really add anything to this other than give it lot’s off time.
Plus it’s easily the best switch i have tried.
Cheers dunc
