Hi.
Niggly little issue… Is there any way to get my phone volume buttons to control the volume in the Naim app? I have ‘use the volume keys for media’ turned on in the android settings but the app isn’t responding when I use them.
Brett
Hi.
Brett
Nope, it’s a pain have the same issue with using Roons app.
Oh well. Thanks for the reply.
I found out that - for me - this as a major advantage when using Spotify!
Yeah… Finding I rarely use the Naim app as just not as user friendly as third party apps (Spotify, Tidal, Pulsar etc.)
