Hi all
I use the Vertere Pulse D-Fi rca cable to connect the gold note ph-10 to xs2 , I’m planning to update the cable and there’re many choices as follow
Tellurium Black II rca
AudioQuest Victoria 5 Pin DIN - RCA
Chord epic
Tellurium ultra black
VAN DEN HUL THE ORCHID
My speaker cable is tellurium black ll and my TT is Rega P10
I don’t know if it worth to go for ultra black ll or chord epic while my speaker cable is tellurium black ll ?
Any help is welcome
Thanks in advance
No, in my system not, but a lot of friend have (where I have listened it) and all by definition are satisfied. Very very musical, musicality at it’s best …
It’s spare part for Linn Akito tonearm …
In standard sale there is only Linn Black T-Cable … You can try it as well … who knows, maybe in your system it will give very musical result …
Also second hand you can try Naim ARO 1 cable … if you find it in mint …
